Having Trouble Cleaning a Pool..
Hey PoolForum, let me first say that I've been trying to research this as much as I possibly can and have taken a liking to poolsolutions for my information.. That being said we're a first time pool owner and probably got stuck with a horrible pool for first timers..
We just got a house that the pool hasn't been used in who knows how long, and probably neglected even longer before that. So its in rough shape, however the filter (cartridge) and pump works. (just got new ball bearings in the pump since it was new but locked up, all good now)
So anywho I started out by shocking the pool.. First time all looked great it started to clear up and the green was going away. However as time went on the pool got very very cloudy and it just never stayed clean. Algae keeps coming back and keeps growing or just building up on the walls. I'm not really sure what to do here.. I've been at this pool for over a month and it doesn't look like its getting better..
I've been trying to keep the chemical levels at the proper amounts but it seems the chlorine level doesn't want to go up at all.
From the little tester the
Chlorine - .6-1? (its not very clear were it is actually its kinda a light yellow but can't really tell the difference)
PH - 7.6
Alkalinity - 100
Hardness - probably around 200 (it was a little lighter than the 250 on the test strip)
I'm not exactly sure about the amount of water in the pool but I estimate around 9k gallons..
Also the pool is really green in that photo cause I just finished brushing the sides, again..
