At this point, unless your pump is just overheating due to high outside temps and poor air circulation, which you might be able to fix by some clean up and a fan . . . you have a choice.
#1 - You can work on the pump and forget about the pool till the pump is running.
OR
#2 - You can run go buy a new pump, install it ASAP and keep working on the pool.
It's just not practical to clean up a pool with no working filtration system. Sorry.
