Results 1 to 10 of 39
Thread: Having Trouble Cleaning a Pool..
    BigDave's Avatar
    Default Re: Having Trouble Cleaning a Pool..
    I'd be willing to bet that the "we'll come out to your pool and evaluate it" will result in suggestions (possibly quite insistent) for chems that will cost alot more than the K-2006. Maybe I'm wrong (and this site is an exception) but there's not alot of altruism in the pool biz, and probably none in a "free service" that's baked into a corporate operating procedure.
    I also seriously doubt that the water changes much in 20 minutes.
    If you collect it with NO air space in a CLEAN plastic or glass container, and keep it reasonably cool, it doesn't change quickly.
    BigDave's Avatar
    Fair enough.
    My point still is: Inviting the pool store over may well cost more than buying a K-2006. Based on the presumption that "free" is never really free.
    I wasn't disagreeing with anything you said, Dave. Just adding a testing comment about how to avoid changes in tested water.
    Thanks,
    Ben
    BigDave's Avatar
    I didn't mean to be defensive, just to emphasize the importance and value of regular testing and monitoring.
    Clearly you're right, laboratory practice is important. You wouldn't get good results if you sucked down a bottle of coke, dipped it in the pool half filling it with the top water, capped it, and let it sit in the bed of the truck in the hot sun (at noon?) on the way to the PS.
    You might be surprised how close to that some people come -- I've seen a little of that, but I bet Waterbear & Waste, having worked in stores, have seen that a LOT.
    Dang! I gotta stop doing that. I might even mess up my truck bed!
  1. Trouble vacuuming the above ground pool
    By cawo1965 in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-19-2013, 10:21 PM
  2. Trouble balancing pool
    By tim665214 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2013, 11:05 PM
  3. new user, old pool, trouble with algae
    By ksukris in forum Dealing with Algae & Slime
    Last Post: 05-25-2012, 02:55 PM
  4. First Pool water trouble
    By Upnorthpoolproblem in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-29-2010, 10:47 PM
  5. Pool filling- but trouble with poolcrete Help!
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 09-05-2006, 11:32 PM
