I recently discovered (through the smart folks on this forum) that I have a leak. When the pump is running and the backwash valve is in the filter position I have water leaking out. I assume this is most likely due to a damaged o-ring in the valve. Would the members have any suggestions for replacing these o-rings myself? Or should it only be done by a professional?
Thanks so much.
