Re: K1005 I-care Test Kit
CarlD
Evan,
You may be one of the few people I know who actually finds the acid and base demand tests useful. But then, as a person who saw LOTS of pools with lots of problems, you might have needed that. But I've never, ever had a need with my two pools. And most people don't. Ben's kits, when he was putting them together, didn't have an acid or base demand test. I STILL use my old PS-233 as my main kit, constantly replacing reagents.
Well, if you have never had acid and base demand tests to use (OR if you have had them and never bothered to use them since they dor require extra steps) you would not know how useful they can be. An analogy is a magnetic stirrer. Most people do not realize how useful one is until they try one (and Taylor now sells an inexpensive one for home use because they ARE very useful for all the titration tests!) Another example would be those that don't think a good test kit (Like the K-2006) is going to make a difference when they are using strips or a cheap 4 way drop test kit. We've all seen a lot of them and what their reaction is after they finally get a good kit.
Sooooo,,,if you have not used acid and base demand tests do not say that they are not useful since you really don't know if they are or not. FWIW,I know Ben chose not to include them in his test kits and can surmise some of his reasons why. I have a PS-234s myself (and two TF-100s, K-2005, K-1005, K-2006 and a few other non Taylor drop based kits and several specialty kits for such things as chloride (salt), borate, metals, nitrate, ammonia, and orthophosphate) and, while the inclusion of the OTO test (K-1000) in some of Ben's kits (If memory serves me right it was not part of the PS232 but only in the PS-233/PS-234/PS-234s) and the TF-100 is a plus in my opinion, I have found the 2000 series comparator and R-0004 reagent (as found in the K-2005/K-2006) more useful for pH testing than the 1000 series comparator and R-0014 reagent. I also realize that adding two comparators and two different pH reagents would be confusing, add to the cost of the kit, and would most likely lead to newbies (and some experienced users) getting the comparators and reagents mixed up!
