Results 1 to 10 of 13
Thread: Mustard Algae in salt system pool
    Sep 2011
    Southeast Georgia
    Default Re: Mustard Algae in salt system pool
    Ben,
    I am actually gone right now. My son called and told me that it was green again. He will be there for awhile tomorrow. Will I cause damage to the pool if I don't do anything to it until I get home in about two weeks? Should I turn off the pump or leave it running. It will be hard for my son to follow the above steps because he is in the military and works 24 hr. shifts. He is not there on a consistant basis. My husband is worried we are ruining the pump, etc. The pool is a 16 x 32 vinyl pool. I sincerely appreciate any help you can give me.
    Thanks,
    Karla
    Damage? Probably not. As long as even a trickle of water flows through your pump and filter, it will be fine. Centrifugal pumps are overloaded by high flow, not low flow. (No flow will boil the water and cause other problems, though.)
    Huge mess? Yeah.
    If your son can't be there consistently, you are pretty limited in options.
    Given your schedule, once you get back you can start working on it. It would help if you have a K2006 testkit (Amazon link in sig) and, if you have a cartridge filter, a new filter cartridge both waiting on you.
    Do NOT use more algaecides and stuff -- it will just make it harder.
    If your son can dump 6 - 8 gallons of PLAIN 6% household bleach in, every time he comes over, that will lessen the problem when you return. But, tell him NOT to wear his expensive uniform when doing so -- bleach seems to jump out and touch you, anytime you wear anything nice.
    Good luck.
    Sep 2011
    Southeast Georgia
    Thank you so much for you help. You don't know how much we appreciate it. Should we leave the pump running while he is putting the bleach in until we return?
    Thanks,
    Karla
    Sep 2011
    Southeast Georgia
    Will the bleach discolor the vinyl liner?
    Thanks,
    Karla
    Not at the doseage that Ben has given you, as long as it doesn't splash on the sides during the addition. The algae in the water will consume the chlorine pretty quickly, so you're not going to have that much bleach in the pool for very long. And I don't know if you ever got a good stabilizer level or not, but if there's any CYA in the water, the amount of bleach Ben is having you add will probably not even do much to clear up the pool--rather, it will help the situation not get any worse until you get back.
    Just make sure that he either pours it in through the skimmer (as long as there is no other chemical in the lines) or pours it slowly, without splashing, into the return stream. Either way will help disperse it through the pool quicker. As a caution, tell him to wear old clothes--I've been putting bleach in my pool for 9 years, and I STILL ruin at least one new shirt each season.
    Sep 2011
    Southeast Georgia
    Janet,
    Thanks for your help. Will we notice anything after the bleach is put in the pool. My son isn't there but my neighbors are doing what they can.
    Thanks,
    Karla
  1. Nature Two Pool System Versus Salt System
    By billie in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-03-2012, 01:27 PM
  2. Wanted: Mustard algae or suspected mustard algae
    Last Post: 08-30-2007, 09:40 PM
  3. Sue's Pool - ? about mustard algae
    By Sue's_pool in forum Dealing with Algae & Slime
    Last Post: 07-29-2006, 10:36 PM
  4. New pool with "Salt" system (and algae) HELP
    By roll tide in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-02-2006, 08:54 AM
