Thread: CYA = 100?
    Aug 2011
    Martinez CA in San Francisco Bay Area
    Default CYA = 100?
    Rather than start a new threat, I'll put my cya question here. My CYA measures at about 100. Two people -- the guy at my local pool store, and the people who do my weekly pool service -- said that levels up to 90 are okay, so they felt 100 was a little high, but not too bad. But elsewhere I see references (like in my Taylor kit) that it should be in the 30-50 range. Sooo, my first question is, is 100 okay or not? And second, is there any way to lower it besides draining out some water and refilling? Thanks in advance.
    John
    15K gallon in-ground plaster pool (30yrs old) - Pentair 420 Clean & Clear Plus cartridge filter
    IntelliFlo Variable Speed pump - Ray-Pac 266 BTU gas heater
    Default Re: CYA = 100?
    I moved your post to a new thread -- it was a different problem than the other one.
    Read the "Best Guess" page linked in my signature, and then ask questions after. It will cover a lot of what you are asking, I think. And it will also give you the info you need to run a pool with CYA=100 successfully.
