Results 1 to 8 of 8
Thread: No Power Light on Goldline Chlorine Generator
    Southern California
    Default Re: No Power Light on Goldline Chlorine Generator
    About two weeks ago, I had the classic No Cell Power msg on my AquaLogic PS-8. I removed the board, found the burned out joint, and resoldered it per the recommendation. Put it back together and all was fine for a week. Now I am getting the Cell Power Error message. I cut the power for 10 minutes and it comes back up, runs fine for 2 days or so, then I get the Cell Power Error back. I have read various posts on the new that range from the system board is bad vs the salt cell is bad or needs to be cleaned. Any thoughts of where to look next is much appreciated.
    mas985's Avatar
    Pleasanton, CA
    It sounds like it might thermal related and the connection fails after some time. I would check the solder joint again and make sure that the PC board and relay are still in contact. If the joint is still looks good, then it could also be the K1 relay element that is connected to that solder joint. A few people have replaced it with some success.
    Mark
