Results 1 to 10 of 10
Thread: Pool opening
    Default
    Get rid of your pool guy. The copper exposure has warped his brain! The copper will create green stains and green hair. There's no quick-fix to algae--you must get and keep your FC level high enough to kill it ALL! At a CYA of 100, I believe the level is 20ppm, but if you don't have a vinyl pool, higher is fine--25 or even 30, until it's clear. At CYA of 100, I believe you must keep your daily FC around 8-10--not sure.
    Bowling Green, Kentucky
    Smile Ben's chart
    I saved this "Best Guess" from last summer.
    Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
    => 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
    => 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
    => 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
    => 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
    => 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
    Default Another question
    I have a solar cover that I left in the pool last summer when I was treating with high levels of chlorine.
    Is it relatively safe to use that again or could it be a source of the yellow dunge algae fever, along with last season's swimswuits, etc.?
    Default
    Quote Originally Posted by GolfTop
    It's still in the pool???? EEEEWWWWW!!!!!
    Default Oops
    Actually, you're welcome for the poorly constructed sentence. I meant while treating for algae during a point in time last summer, I left it in the highly chlorinated pool. Trust me, it's safely tucked away in my garage, having been cleaned, dried and awaiting word on whether it will get another summer's worth of duty.
    Default No one care to weigh in?
    I got a funny response to my question about pool toys, etc., but no real answer. My question again, last season had yellow algae, should I toss the old pool toys, swimsuits, etc., or can those still be used? Under no circumstances do I want to accidently reintroduce that mustard into my pool.
    Thanks in advance.
    duraleigh Guest
    Default
    Hi, Golftop,
    I'd put it all straight in the pool. Chlorine kills algae....you super-chlorinated....algae should be gone.
    I have no personal experience nor scientific knowledge but logic tells me you have no problems.
    Dave S.
  1. opening our pool, could use some help
    By grayspinner in forum Dealing with Algae & Slime
    Last Post: 05-29-2011, 04:55 PM
  2. Pool opening on the way!
    By CarlD in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-06-2009, 12:30 AM
  3. My pool opening?
    By KLHink in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-06-2007, 05:27 PM
  4. Opening AG Pool
    By Ken S in forum Above-Ground Pool Construction & Repair
    Last Post: 01-30-2007, 10:35 PM
  5. Opening pool
    By brian87gt in forum Dealing with Algae & Slime
    Last Post: 05-28-2006, 02:28 AM
