Thread: How do I test for metals in water?
    Lincolnton, NC
    Default How do I test for metals in water?
    I am having an issue with a slight green tint to my pool. I opened a week ago and the pool has been clear util I put the recommended dosing of bleach in yesterday. It is at shock level of 15ppm. All other #'s are good. Maybe the bleach is reacting with metals in water. How do I test for metals?
    ivyleager is offline Lifetime Member Weir Watcher ivyleager 0
    North Carolina
    Default Re: How do I test for metals in water?
    Just off the top of my head, I know my local pool store is able to test for copper. Can't recall if they test for iron, though. I do know they have some kind of Taylor reagent you can purchase that will test for iron.
    Hope this helps.
    CaryB
    Go 'Canes!
    duraleigh Guest
    T,
    Your posts are difficult to follow. Your first post indicated a slightly green tint to your water. Then you replied it was more like red. Now, it is apparently back green again. Is that correct??
    Lincolnton, NC
    Quote Originally Posted by duraleigh
    T,
    I am sorry for the confusion D. In low light the water haas a somewhat amber tint against the blue liner. The tint is actually a greenis color. The pool was clear until I added the bleach. So I am thinking there is copper content in the water. I am having it tested today.
    mbar's Avatar
    Ashland, PA
    Lower your water a little, check to see if there is any staining on your pool. Blue and yellow make green - I had this happen in my pool - I thought that the water was green, but when I lowered the water I noticed that my whole pool was tinted yellow from staining - so this is just a suggestion. If it is staining we can tell you how to get rid of it.
    Northeast PA
  1. Bucket test for metals question
    By pedsrn in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-06-2012, 04:21 PM
  2. Bucket test for metals
    By PoolDoc in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 06-17-2012, 06:58 PM
  3. Recommendation for DIY Test Kit for Metals
    By Gracy101 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-19-2007, 02:26 AM
