Press the PUMP button. If it says REMOTE RUNS PUMP, you've got to program it for EXTERNAL TIMER or ONE SPEED PUMP (if you're controlling your pump through the DIG).
Run your test mode after letting the cell run in BOOST at least a minute. If it has not been energized, you won't get a good amp and volt reading.
