Thread: Help unlocking the Navigator locking vac lock flap
    Default Help unlocking the Navigator locking vac lock flap
    We have a Navigator pool cleaner with a locking Vac Lock on the pool end side. W pulled the NAvigator out to go swimming yesterday, the flap closed and now I cant get it open. The manual does not show how to unlock the flap, can anybody help this poor sole...
    Thanks,
    Brian
    Default Re: Help unlocking the Navigator locking vac lock flap
    make sure the pump is off (you have no chance if it's on), then use a flat edge (regular) screw driver to pry it open. There is a notch on the bottom and the screw driver head should fit in there and then just give it a twist. I can open mine by leaning over the edge without having to get in the pool.
    -- john
    Thanks John that worked.
