Re: Chlorine generator question
Thanks everyone. I will definitely buy the test kit, but I think I'll work on actually getting the pool first. Good to know that forum gets a little piece when buying through the links on their sigs. This place rocks, and I'm happy to help out where I can. The Liquidator does seem like a convenient thing to have, but I can't find reviews about how they hold up year to year. Also, would I be able to leave it outside over the winter, or would I need to bring it in or winterize it somehow?
Also, I've got a really stupid question about BBB. When putting bleach into your pool, do you just lean over the side and dump it in? I know you have to be careful with splashing on the liner, clothes, etc, but if I dump a gallon of bleach over the sidewall on a 30' pool, won't I need to stir it, or do I just pour it in when the pump is running and that helps distribute it? I searched for an answer on this because quite frankly I was embarrassed to ask as it's probably common sense, but being new to pools in general, I want to make sure I understand everything. Once I pour it in, should I wait a little while before going in the water?
