Thread: How much borax
    lstinthot is offline PF Supporter Thread Analyst lstinthot 0
    Aug 2011
    Default How much borax
    Water has been looking pretty good. This mornings results are:
    Ph 7.2
    TA 110
    CH 180
    CYA 60
    CL 4.5
    CC 0
    Was going to raise the Ph, but when I was reading on here how much borax to add I read a tread that talked about raising Borates to 50 ppm. I have not been looking at borates at all. Why do we want borates at 50 ppm? I could not find any other reason why, just some threads that talked about using borax and acid to get it to 50 ppm.
    Thanks,
    Mike
    ~36,000g IG gunite -- 2Hp Pentair UltraFlow filter pump - replaced with 2 speed 1 1/2 HP ultraquite pump -- 3/4 HP vacuum booster pump -- DE filter --K-2006 test kit
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: How much borax
    borax is used for two distinct things:
    1) to raise pH without having any great impact on the total alkalinity.
    2) in much larger quantities to bring the borate level to 50 ppm to act as an algaestat and to introduce a secondary pH buffer that works in the opposite directon of the bicarbonate buffer we call TA. This tends to 'lock' the pH at around 7.7 for an extended period of time and is particularly useful with SWCG's (salt pools) but useful in any pool, IMHO.It also gives the water a clarity and 'sparkle' that has been commented on time and again. Much larger quantities of borax are needed to get to 50 ppm borate and since borax is alkaline, unless acid is added in the correct quantity at the same time to keep the pH in check, the pH would be extremely high.
    As to why 50 ppm--the original research and patents by John Garvin, Proteam, and Bioguard determined that 30 to 50 ppm is optimum for algaestatic and buffer effect in chlorine and bromine systems and that 50 to 80 ppm is needed for algaestatic effect in biguanide (Baqua and SoftSwim) systems.
