I have one or 2 small areas ( about 6-10 sq in) on long side of pool between the pump inlet and the sidewall return about 2.5 ft down that algae begins to show every 10 -15 days. I believe it is a dead spot in the circulation altho I run pump 24/7. Been using BBB for about 1 yr and have been fighting algae on & off. Been using chemgeeks 15% CYA and Ben's shock 30% for control & elimination of algae growth and I have concluded (??) poor circulation may be my problem.
The pool is in-ground 16X32-18,500 gal vinyl lined and my pump inlet (@40 gpm) to pool is 1.5 ft below surface . In addition to the skimmer on the long side opposite inlet, I have a return on the opposite long end of the inlet. The growth appears on the long side 1/2 way between return and inlet. The sand filter nomenclature plate is unreadable however the diameter is about 18" and 24" tall.
Stats today:
CYA=45
pH=7.4
TA=90
FC= 5.5 - 7
My question then is if I were to increase FC residual is it possible to offset the growth due to poor circulation or should I just get in the habit of brushing the area every week? BTW-didn't have this problem before converting last year, however I did spend a lot money on algaecides, shocks etc.
