Thread: Air in the system
    SW Missouri
    Default Re: Air in the system
    Check that o-ring on the pump basket and make sure it is intact. I have used silicone grease on mine in the past to eliminate air getting into the system. Just take out the o-ring and lightly coat it with a good quality silicone grease and be sure to get the basket cover back on snuggly. Those o-rings develop small cracks as they age and the grease will often times be enough to forego replacement of the ring. This has worked for me for several years. Also you can use the grease on your basket and pump drain plug o-rings and threads to make a more effective seal as well. Good luck!
    20,000 Gallon IG Vinyl (first season 2000)
    Solar Heat
    2 Speed Rebuilt pump
    Sand filter
    cooldude.com/pool-1.jpg
    Jun 2010
    Texas
    Thanks to all of your replies. I will check (hopefully tomorrow) and report back!
  1. Nature Two Pool System Versus Salt System
    By billie in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-03-2012, 01:27 PM
  2. Rattle in system
    By TJG55 in forum Pool Equipment & Operations
    Last Post: 06-07-2012, 05:07 PM
  3. New member, need help with pop up system
    By Reedus in forum Pool Equipment & Operations
    Last Post: 09-30-2011, 08:03 PM
  4. Air in system
    By roryqueale in forum Pool Equipment & Operations
    Last Post: 05-30-2011, 11:23 PM
  5. Air in my system
    By RENOPOOL in forum Pool Equipment & Operations
    Last Post: 06-05-2006, 10:54 AM
