Thread: No drain acid wash
    Sep 2011
    Default No drain acid wash
    We will be doing a second follow up no drain acid wash on our 30,000 gallon pool. The first time around we used 5.5 gallons of acid with good results in removing residual plaster dust leftover from the original startup. Now there are a few stubborn patches of a milky gray color on the pool floor, and a few areas on the walls.
    The plaster is Stonescapes Tahoe Blue and for the most part looks better than ever.
    It was suggested to use from 10 - 12 gallons of acid to clean up the rest of the dust. Does this sound like the right amount? I was told we did not use enough the first time and that's why we still have a few areas that need to cleaned up.
  1. Would you Acid Wash
    By topcorner in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2011, 05:29 PM
  2. Acid Wash
    By txhomebrew in forum In-Ground Pool Construction and Repair
    Last Post: 03-19-2009, 12:52 PM
  3. Any alternative to acid wash?
    By framcus in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-20-2007, 06:08 PM
  4. Acid wash new 3m plaster?
    By No Need in forum In-Ground Pool Construction and Repair
    Last Post: 04-17-2007, 07:09 PM
  5. acid wash pebble tec?
    By vchavez in forum In-Ground Pool Construction and Repair
    Last Post: 02-28-2007, 11:39 AM
