Thread: Aqualink Problems HELP
    Sep 2011
    Default Aqualink Problems HELP
    I'm brand new here so please bear with me. Our Aqualink RS6 completely died this morning. The inside control panel and the outside panel will not turn on. We checked for dead fuses and comfirmed power is going to the unit. Not sure what to do here. I know this is an expensive replacement and would like to insure that a purchase is truly necessary. Any troubleshooting advice out there?
    Default Re: Aqualink Problems HELP
    I can't help you much with trouble shooting the unit, except to say, check the online manual that is probably available.
    But . . . I can tell you that you can (and should) pretend you have a non-SWCG pool, and treat your pool with bleach in the mean time. Add 1 gallon of plain 6% household bleach per 10,000 gallons of pool water each evening, unless the chlorine shows too high.
    If you post test results and pool gallons, I can give you more specific info. If you don't have a K2006 or equiv (DPD-FAS chlorine test kit) go purchase a cheap OTO/phenol red kit and use that rather than "guess strips". You'll need to take your water in so you can get a CYA reading --- dealer-read guess strips are somewhat better than consumer-eyeballed strips, though still not very accurate. (Get a K2006!)
    Round Rock, Texas, USA.
  1. aqualink rs8 problem
    By dir1944 in forum Pool Electronics
    Last Post: 06-04-2013, 09:25 AM
  2. Jandy Aqualink PDA
    By abrenner in forum Pool Equipment & Operations
    Last Post: 04-29-2012, 06:16 PM
  3. Aqualink PDA-PS8 Wiring
    By VrRotate in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2012, 03:37 PM
  4. Aqualink problems
    By jscribn1 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 09-07-2010, 05:26 PM
  5. HELP with Jandy Aqualink RS 8
    By captgene in forum Pool Equipment & Operations
    Last Post: 05-24-2010, 04:28 PM
