I'm using the CYA test in the Leslie's DPD test kit (the one where you add water until the black dot at the bottom of the cylinder disappears). I checked it twice.Originally Posted by bbb
Great - I was hoping you were using the black dot test. I just wanted to make sure you were using the proper test, and not just a pool store printout or test strip, before going through all the effort of a drain/refill. As others on the post have said, if you get the CYA down between 50 and 100, you can certainly successfully run the pool (using the higher Cl amounts suggested in Ben's "best guess" table), so make your own judgement about the target level based on the amount of effort you want to put in, the cost and quality of your fill water, etc.Originally Posted by xcapecod83
Good luck!
bbb = bleach, borax, & baking soda
I have been battling an elevated CYA for the past month- found out it was elevated by chance- my pool store must not have tested for it because I never was told it was a problem. Reading of around 150. Have a fiberglass pool and was told by installer that I could not empty it more than 12 "- I have done that twice with very little inmprovement. I waqs swimming in the pool- which looks great by the way, I just have to keep using chlorine- am I in any danger using the pool?:
Couldn't you simply use two hoses: one is siphoning water out while at the same time a different hose is adding new water? This wouldn't remove CYA as fast (and you'd waste more water) but this would avoid having to empty the pool at all...
I've never needed to drain so I'm just hypothesizing that this method would work.. wouldn't it?
