Closed Thread
Results 1 to 9 of 9
Thread: My first Shotcrete pool
    Waterworks is offline In the pool biz Thread Analyst Waterworks 0
    Default Re: My first Shotcrete pool
    Thanks Fig and Duraleigh. I'm just trying to get this straight. Basically, I'm going to cut my flagstone so that the deck-side of the stone is fairly even with the back of the beam all the way around the pool. Then I add poly-void to the back and grout on the top. Then install my decking.
    Does anything change because the deck is dry-set and will not be on a concrete base and also not mortared or grouted in?
    Brad
    Waterworks
    duraleigh Guest
    Hi, Brad,
    As posted, I am a rookie on this but I do understand the principle. That is, put some type of flexible connection between the pool wall and the decking....otherwise, it will crack.
    So, since your drysetting, it makes sense to me that your flexible connection will take place automatically because you do not intend to mortar the joints.
    I understand what fig is saying by mortaring the first row or coping to the bond beam....that makes sense, too. That would mean to me an expansion joint between the flagstone coping and waterline tile is unnecessary and not workable anyway.
    If we're all on the same page, it would then seem logical to me that it is not necessary to use polyvoid since you are using no grout on the remainder of the decking material.
    I'm on fairly thin ice and fig understands this better than me. I did a poured concrete decking....as you said..different animal.
    I was thinking the same thing. If my deck won't be anchored to anything than I shouldn't need an expansion joint and the individual stones can move on their own. And the coping pieces would need to be mortared down because otherwise they could just topple into the pool. Thanks
    Brad
    If your going to just put sand between the deck stones then you will not need the caulk. Two things to think about though, one don't let the deck stones touch the pool coping stones and two if you are doing a sand set on the deck stones and water is allowed to to drain down between the coping stone and the deck stone then make sure the water will drain away from the bond beam of the pool (this is important if you live in an area that has freezing weather). If you are going to mortar between the stones on the sand base then you will need to caulk between the coping stone and the deck because you do not want a void space and you do not want mortar between them. Hope this helps.
    That's great Fig, I appreciate the help. Once we're all done I'll post some pictures.
    Brad
Closed Thread
