Results 1 to 10 of 10
Thread: Getting started
    Oct 2011
    Riverside, California
    Default Re: Getting started
    Thanks PoolDoc. I will definitely get quotes from a few companies and do research on them before I make a decision. I absolutely want it done right. Would you repaint the surface if the surface under the old paint is in good condition or is there a better product you can recommend other than paint? I understand that painting is something that if done right will last up to 6 years or so.
    Kelley Technical's Zeron can last up to 6 years if done right, but don't count on more than 5. Check out their site:
    http://www.kelleytech.com/
    for what is, and isn't possible.
    I'm sure that some of the other paints are OK, but I know that some of them are not, and I don't have reliable info on which are which . . . so I'd recommend Kelley.
    Do NOT let a contractor apply it thinly to save money and make application easier: YOU buy the paint and make SURE it all goes on the pool! Doheny's online has had fairly good prices.
    Oct 2011
    Ok. Thanks for the advice
    Oct 2011
    I have been researching the BBB method and I am unsure of one thing, does the bleach replace the chlorine tabs or is it used along with the tabs? I think it replaces the tabs but want to be sure. Also I was price checking the BBB products vs. There pool store counter parts and found that typically a 4 lb. Box of baking soda was more ($17) than a 5 lb. Bucket of alkalinity up ($13). but kept searching and found a 12 lb. Bag of baking soda for ($7). Where is a good place to shop for these products? I was using amazon
    Quote Originally Posted by Lowdown View Post
    Ben already answered this part of your question in your other thread.
    You can buy a big bag (maybe 10 or 12 lbs?) cheap at Sam's Club.
    Oct 2011
    Other thread? I was unaware I had another thread. Weird. This is the only thread that I'm aware of that I created. Trying to search now for my other thread, only prob. Is I don't know where it is or the title. I wasn't sure my question went through, I came back here a few times and no one answered, so I asked again. Sorry for confusion will continue to try to find this other thread you speak of. If you would be so kind as to point me in the right direction to find the thread I would appreciate it. Thanks Watermom
    Oct 2011
    I found it. Thanks
    BigDave's Avatar
    ... I was price checking the BBB products vs. There pool store counter parts and found that typically a 4 lb. Box of baking soda was more ($17) than a 5 lb. Bucket of alkalinity up ($13)... I was using amazon
    Yo, LowDown. Got the straight dope, on the down low. A grocery store has the 64oz A&H for $2.79 here on the right coast. Check a left coast grocery. Yo.
