Results 1 to 8 of 8
Thread: spa water level
    Aug 2011
    Martinez CA in San Francisco Bay Area
    Default spa water level
    I have an attached spa and pool, where the spa water spills over into the pool. When I want to heat the spa, I have the suction line valve turned to "spa" and the return line valve also turned to "spa," so I am taking water from the spa, heating it, and returning it to the spa (rather than taking pool water).
    But when I do this, the water level in the spa goes down significantly, so I guess it's taking water at a greater rate than it's returning it. Is this normal, or is there a problem? Doesn't seem right to me. Thanks in advance for your help.
    John
    15K gallon in-ground plaster pool (30yrs old) - Pentair 420 Clean & Clear Plus cartridge filter
    IntelliFlo Variable Speed pump - Ray-Pac 266 BTU gas heater
    Largo, Florida
    Default Re: spa water level
    On my spillover spa setup there are two spa valves. One of which can be used in conjunction with pool returns/waterfall, and the other of which is used to generate bubbles and is used for spa only operation like you are trying to do. My guess is you have something like this going on, or you have some kind of leak.
    Maybe put your hand in front of all the pool returns while you have it set to spa and see if you've got anything coming out into the pool while you have things set to spa?
    If this happens only when in spa only position it could be a bad valve on the spa/pool return is letting water back into the pool when it is not supposed to.
    Aug 2011
    thanks for both of your replies, I will check these things out.
    - John
    John
    Aug 2011
    It turned out to be a leaky valve. I just got new valves and some new piping put in. Problem solved. Thanks for your responses.
    John
    It's actually a fairly common problem and the first thing to check! Glad you got it taken care of.
    Jul 2011
    Boca Raton, FL
    I'm glad this thread was posted! I have the *exact* same experience. I get around it by drawing a little water from the pool, but since my equipment is under warranty, I'll ask the builder to fix/replace the faulty return valve.
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    Aug 2011
    good luck, famous. hope it works out as planned.
    John
  1. Water Level - HELP!
    By itsparadise in forum Above-Ground Pool Construction & Repair
    Last Post: 05-26-2012, 05:14 PM
  2. water level
    By Barry J in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-23-2011, 01:11 PM
  3. Topping off water level
    By pool newby in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-22-2007, 12:59 PM
  4. water level dropping
    By carolynn in forum In-Ground Pool Construction and Repair
    Last Post: 08-03-2006, 04:49 PM
  5. how to use a water level?
    By amyinraleigh in forum Above-Ground Pool Construction & Repair
    Last Post: 07-17-2006, 08:34 PM
