Results 1 to 8 of 8
Thread: spa water level
    Aug 2011
    Martinez CA in San Francisco Bay Area
    Default Re: spa water level
    It turned out to be a leaky valve. I just got new valves and some new piping put in. Problem solved. Thanks for your responses.
    John
    15K gallon in-ground plaster pool (30yrs old) - Pentair 420 Clean & Clear Plus cartridge filter
    IntelliFlo Variable Speed pump - Ray-Pac 266 BTU gas heater
    It's actually a fairly common problem and the first thing to check! Glad you got it taken care of.
    Jul 2011
    Boca Raton, FL
    I'm glad this thread was posted! I have the *exact* same experience. I get around it by drawing a little water from the pool, but since my equipment is under warranty, I'll ask the builder to fix/replace the faulty return valve.
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    Aug 2011
    good luck, famous. hope it works out as planned.
    John
