Thread: How to clean Slot Drain
    Oct 2011
    Florida
    Default How to clean Slot Drain
    Between the pool apron and the adjoining concrete patio area, is a slot drain to catch run-off from the pool. Mine is full of dirt, with small plants growing in some holes. How does one clean this drain? If anyone has one, and knows how to clean it, I'd be most appreciative in hearing from you. Thanks. Gary/Homosassa, FL
    Default Re: How to clean Slot Drain
    Can't say I have a definitive answer, but I'd probably try to start at the end -- where the water drains out -- and try to work a hose up the pipe, in a reverse direction, flushing as I went.
  1. oxy clean
    By johnlanciloti in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-24-2011, 08:19 PM
  2. Do I need to clean my SWG cells?
    By Jeffski in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-06-2007, 02:20 PM
  3. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
  4. PB wants to drain pool- to clean rough poolkrete
    By webfeet in forum In-Ground Pool Construction and Repair
    Last Post: 09-21-2006, 11:03 PM
  5. Pool Drain or No Pool Drain (Skimmers vs. Jets)
    By michelle73 in forum In-Ground Pool Construction and Repair
    Last Post: 08-15-2006, 02:22 PM
