Thread: Leaking Plastic Manifold on Pentair Mini-Max - How to Fix?
    Nov 2011
    Default Leaking Plastic Manifold on Pentair Mini-Max - How to Fix?
    Hello, My mini-max NT has a leak at the end of the plastic manifold that is adjacent to the in and out pipes. There is a plastic cap sealed onto the end of the manifold that is slowly dripping water. It does not appear to be PVC. I can replace the leaking part for about $90 but I was hoping I might be able to seal the slow leak with some sort of adhesive.
    Question, Anyone know what kind of plastic Pentair uses on their heaters and/or what kind of adhesive could be used to seal this leak up?
    Thanks!
    Default Re: Leaking Plastic Manifold on Pentair Mini-Max - How to Fix?
    Hi and welcome to the forum! Sorry you haven't gotten a reply yet. Ben has had some issues he has had to deal with the past few days and thus he hasn't yet been able to move these new posts into the general part of the forum where you'll be able to get some advice. But, he'll hopefully be able to do so soon. So, sit tight. Just wanted to let you know that your post has been read and that you aren't being ignored!
  1. Cracked DE Filter Manifold
    By Shifty in forum Pool Equipment & Operations
    Last Post: 05-13-2013, 08:46 PM
  2. Pentair FNS filter - Hi-flow valve leaking out to backwash
    By naztuk in forum Pool Equipment & Operations
    Last Post: 11-03-2010, 06:46 PM
  3. Dimensions of the pool Pilot manifold
    By skipcoon in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-16-2008, 11:22 AM
  4. heater manifold leaking
    By Deuce2 in forum Pool Equipment & Operations
    Last Post: 05-27-2007, 12:25 AM
  5. Water leaking from PoolPilot manifold assembly
    By bbb in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-16-2007, 10:43 AM
