Thread: jandy pump frozen up..
    Nov 2011
    Default jandy pump frozen up..
    My Jandy pump hums then trips circuit breaker. Is there a simple trouble shooting process?
    Default Re: jandy pump frozen up..
    There are several steps, that can help you check the motor and pump out, BUT . . . unless you are able to repair a pump, replace a capacitor, or replace a pump motor yourself, it doesn't really matter.
    If you are going to have someone else do the work, you might was well let them do the diagnostics.
    At a minimum, you need to understand and be able to use a voltmeter -- if you don't already have one, this may not be the time to start.
