Thread: Should there be a radius or cove between pool Krete floor and steel wall of ig pool?
    Nov 2011
    Panama City FL
    Default Should there be a radius or cove between pool Krete floor and steel wall of ig pool?
    I am getting close to starting the pool krete floor of my diy inground steel wall vinyl lined pool and am having trouble finding a clear answer to this question. Is the intersection between the floor and wall in the shallow end 90 degrees, or is a radius preferable?
    Default Re: Should there be a radius or cove between pool Krete floor and steel wall of ig po
    Hi and welcome to the forum! Sorry you haven't gotten a reply yet. Ben has had some issues he has had to deal with the past few days and thus he hasn't yet been able to move these new posts into the general part of the forum where you'll be able to get the advice of some of our builders. But, he'll hopefully be able to do so soon. So, sit tight. Just wanted to let you know that your post has been read and that you aren't being ignored!
    BTW --- I deleted your other duplicate thread.
    In general, it's hard to get liners to fit 90 degree angles.
    BUT . . . you should go with what YOUR liner manufacturer says to do.
