The particular problem you describe is common, but isn't necessarily the ozone mfg's fault. Your pool builder may well have installed it incorrectly: many builders do not know how to avoid pump bypass loops that can allow a pump to lose prime. In many cases, if the unit was installed with small tubing, you can simply bend the tubing till it crimps, and then use electrical tape to hold it crimped till your builder can fix it.
