Re: Pink slime!
Thanks for your reply, CarlD.
My SWCG levels are correct. Jandy recommends CYA levels between 50 and 75 (higher if pool temps are 85 degrees or more, which my pool is not). Since my average FC level is 3.0, that's a little more than 5% of the CYA level, so I should be good on that account. But since my CYA level was at the low end of the recommended range, I added more CYA as you suggested.
I don't think I've got an algae problem because my CC levels are never higher than 0.5, and often 0.0 (more a factor of how I test the water, I think). My FC levels move only very slightly overnight. And, I add a weekly dose of polyquat 60 just to stave off any algae problems. I think the pink slime (bacteria) just happens to tolerate my pool's conditions as they currently are. I think your advice is still sound, though, so I used the "Boost" mode on the SWCG which raises FC about 12ppm over 24 hours.
I did forget to mention my pH level! I keep it between 7.2 and 7.8 (Jandy's recommended range again). On the day it hits 7.8, I add acid to bring it back down to about 7.2 or 7.4. My pool's pH rises 0.1 daily on average, so I add acid about every 6 days or so.
And it's not so much that I'm losing the tile grout because of water conditions, it's just that the pool builder guy doing the trowel work with the tiles didn't happen to do a good job filling in the space between these few tiles on one end of the swim out. I'm not seeing any issues with the pool except that one place on the swim out.
So, in short, I added CYA, boosted the chlorine, and will continue to just monitor things. I may try the underwater epoxy assuming it comes in some sort of shade of white. Hopefully the shocked pool will kill off the pink slime bacteria for now, and I'll keep on top of my son so he regularly brushes down the pool walls and floor on a weekly basis.
South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
