Results 1 to 10 of 18
Thread: Pink slime!
    Jul 2011
    Boca Raton, FL
    Default Re: Pink slime!
    Thanks waterbear. My TA tends to drop over time, so I can just not adjust it whenever it falls to 70, then. I'll hit the nearby pool store this weekend to pick up whatever it is that increases calcium. And I'll up my FC a little beyond 3, and see if the pink slime stays away (actually, it's already 6.0 because of when I hit the Boost button; I tamped down the SWCG % ontime just 10% following the Boost, so the FC would fall very slowly, which it has). I'll try keeping FC no less than 5% with the higher CYA level.
    I looked over my pool records today. My pH rose 0.05 per day over the last 10 days, where the waterfall wasn't running, where I had my pool covered, and where the water temp was between 81 and 77. That's a slower pace than when my pool is uncovered and the waterfall is running; that's when I see up to a 0.1 rise per day (sometimes it's a little less than that, actually, but it's very close to 0.1).
    This morning I uncovered the pool where the pink slime had been earlier; no pink slime visible from above the surface of the water. I'll uncover the pool this weekend and examine everything more closely to see what's going on.
    Thanks again!
    South Florida - 16,000g Diamond Brite pool, 700g spa & waterfall, Jandy 1400 AquaPure SWCG, Jandy variable-speed 1.5H pump, Jandy 60 DE filter, Jandy heat pump - using Taylor K-2006 kit
    Jul 2011
    Boca Raton, FL
    What's the difference between calcium chloride dihydrate and calcium chloride? Is one preferred over the other?
    Quote Originally Posted by famousdavis View Post
    Only difference is the amount needed to achieve the same rise in calcium hardness. The dihydrate has two water molecules attached to it so it weighs more so you need to add more. Whichever you can get is fine. I have found the dihydrate is more readily available and usually buy the Tetra brand in 50 lb bags. Dowflake and Peladow is usable but it does have a higher bromide content (although not as much as if you add a sodium bromide based mustard algae killer).
    Jul 2011
    Boca Raton, FL
    Nice plan waterbear!!!! :-)
    Many thanks for not just your advice, but for your explanations on why you're giving your advice!
    Jul 2011
    Boca Raton, FL
    waterbear's Checklist:
    "Raise the CYA to 80 ppm and run your FC between 4-5 ppm and you will be golden." (I added the last pound of stabilizer that I had, so the CYA is probably about 60 now; FC still running about 6.0, but it should fall since I'm running the SWCG less time now)
    Drop the TA to 70 ppm (it's at 80 now; I'll just let it fall to 70 on its own over time)
    Keep the CH between 400-450 (I boosted CH way up to just under 400 now. Will top off next weekend after I'm assured my CH addition yesterday is thoroughly mixed)
    Keep the pH no lower than 7.6 and drop it when it hits 8.0 (it was at 7.4 Saturday, and is probably 7.6 today; I'll add less acid when it's time to adjust the pH downward)
    Keep salt between 3000 and 3500 ppm (currently running 3.3 or 3.4 according to the SWCG; pool store co's said it's a bit lower than that reading)
    I checked the SWCH plates and sensor yesterday -- first time ever since getting our pool last May! -- and the sensors were spotless, the plates had no build-up of any gunk that I could see. I'll check on that again since I'm running higher calcium now, to ensure the plates and sensor stay clean.
    And there was no pink slime to be seen anywhere in the pool this weekend. Lookin' good!
    Of course they were since you have been running a negative CSI for a while and have aggressive water that will dissolve calcium.
    They should. If you check the CSI range for the parameters I gave you will find that it ranges from about -.3 to about +.24 which is balanced water! (This is with the TA at 70 ppm. At 80 ppm the water will have a bit more tendency to scale so you might want to think about dropping the TA by 10 ppm since , if you are not overdosing on acid, your TA should stay fairly stable for a while.)
    Use you acid demand test to get an idea of how much acid to add. I measure the acid into a plastic measuring cup that I put on a plastic dinner tray. If any spills I jut push the whole tray into the pool. One you get used to how much acid your pool takes you can eyeball it pretty close but you really should measure at first. If you don't want to measure acid then get a gallon jug and fill it with water and measure that to get your eyeballing of the acid more accurate. It's just practice.
    Jul 2011
    Boca Raton, FL
    Oddly, my pool's pH read 7.4 today -- same as it was three days ago! While I haven't been using the waterfall, I've never had the pH be stable for three days in a row. Weird! Pool temp is 79, no change there. Does calcium somehow stabilize pH, too?
    My FC hit 4.5 today, so I'll readjust the SWCG back to its original setting (50%) and see if the FC stays the same.
    That is because you have bee just dumping in acid and doopping the pH too low when you add it. When you add acid you lower both TA and pH but you lower TA MUCH SLOWER than pH. Another reason to not drop the pH as much...if you read the stickly on the procedure to lower TA is it to:
    Drop the pH low (7.0 to 7.2) to lower TA AND pH
    Aerate to raise pH without affecting TA by outgassing CO2
    repeat until TA is where you want it.
    AS I said before, the LOWER you drop the pH the MORE you outgas CO2 and the FASTER the pH rises. What I did not add to that is the FASTER the TA will drop!
    If you only want to drop the pH from, say, 8.0 to 7.6 then use the acid demand test in your K-2006 and get an idea of how much acid is needed to lower the pH. I think you will find you have been overdosing on acid! Once you do that I think you will find that your TA is much more stable. It is normal for TA to drop over time but it should not need upward adjustment very often at all if you are not using an acidic chlorine source like trichlor. What is the TA of your fill water?
    As far as your CYA and FC, remember this is a pool, not a science experiment. Keep it simple and don't lose sleep over it Raise the CYA to 80 ppm and run your FC between 4-5 ppm and you will be golden.
    If you do this your water will be balanced over a temperature range of about 70 to 90 degrees! Easy! (At water temps below about 75 degrees don't let the pH drop below about 7.8 if you lower pH but as long as it is below 8.0 I would not worry about it.)
