I would definitely turn the SWCG off--can you do that and still run your pump? In cold water it takes a lot longer for chlorine to be used up than it does in warm water, especially with a cover on it where the sun can't help decrease it. In my pool, I usually add 3-5 of the large jugs of bleach weekly during the swim season, but when the water gets cold I can decrease it to 1of the same size jug a week and still maintain a high chlorine level.
If you can turn off the SWCG, and leave the cover off, the sun will eventually bring the chlorine down, although it may take several more days. Alternatively, you could add a dose of Polyquat 60 algaecide (the only algaecide we recommend using here), because it also will cause a drop in chlorine levels. What type of surface is your pool? If it's plaster or gunite, and bleaching of color isn't an issue, I would just let the sun take care of the high chlorine levels. If you have a vinyl liner, though, I would go ahead and drop the chlorine level a little faster, knowing that if there's bleaching of your liner that will happen, it's probably already done...
