Re: Wanting to start right
Hi seetide, and welcome to the forum!
The negative effects of adding tabs into skimmers are that 1) the tabs AND the dichlor will drop the pH of the pool water, so you need to be careful that your pH stays where it needs to be, but more importantly 2) that low pH water gets concentrated in the skimmers while the pump is off, so when you turn the pump on, it gets a blast of high-chlorine, low pH water, which can corrode pipes and pump parts. 3) In addition, there have been reports of fading of vinyl liners right around the outside of the skimmer from pucks sitting in the skimmer with the pump off. So...if you use pucks in the skimmer, we highly recommend that you keep the pump running all the time, and keep an eye on your pH. Oh, forgot to mention 4) both dichlor and trichlor tabs raise CYA, so you need to keep an eye on the CYA levels so that they don't get so high that you can't compensate with higher chlorine levels.
Kudos to you on taking the time and effort to learn about pool chemistry. We'll be glad to answer any questions you might have, but take some time and read through the forum and on our sister site, PoolSolutions.com
