Results 1 to 10 of 10
Thread: Cement Coping: 2 x 4 Marks in the dried coping: how to remove them?
    Default Re: Cement Coping: 2 x 4 Marks in the dried coping: how to remove them?
    I'm not sure I'm ready to elevate my guesses to a full-blown suggestion.
    I've seen marks like those 'age out' of concrete, but I don't have ANY understanding of exactly what causes those marks (I mean chemically; I know how to 'make' them), and I don't have the sort of experience that would allow me to say that what I've seen happen elsewhere, will happen to your pool.
    If you can wait, wait. See if you get another answer from someone with more experience and more confidence in their answer.
    I don't know if there's some sort of concrete forum on the Net; if there is, you might want to post there, because marks like these aren't unique to pools. You can use the links to the photos here. Since I put them on Picasa, it's not costing me anything for someone to download a meg's worth of image files.
    If you do find an answer elsewhere, post it back here, if you don't mind.
    Dec 2011
    Beverly Hills, CA
    Will do and thanks again; if you hear of anything new, please pass it on to me. I'll read this column for the next couple of weeks, and again I thank you for taking the time to reach out and help.
    S.
    Unless you have disabled that feature in your profile, you should automatically receive emails, any time someone posts to this thread.
    Dec 2011
    Beverly Hills, CA
    My contractor had one spare coping piece sandblasted and that WORKED! So I am going to have the entire coping around the pool sandblasted and then stained to keep the alkalie from leeching through. Thanks for helping me noodle this problem.
    Dec 2011
    Beverly Hills, CA
    After sandblasting new concrete coping, what is the best sealer? A Lithium Sealer which is supposed to last 30 years, or a good sealer that lasts for 2-4 years. Is a Lithium Sealer good for Southern California outdoor, in the ground pool coping?
  1. what kind of cement to use for stone coping and steel pool wall?
    By leon718 in forum In-Ground Pool Construction and Repair
    Last Post: 06-05-2012, 04:14 PM
  2. New coping for SWG pool
    By jbuckste in forum In-Ground Pool Construction and Repair
    Last Post: 05-04-2009, 11:45 AM
  3. Concrete coping vs. rim lock coping
    By Sean-NJ in forum In-Ground Pool Construction and Repair
    Last Post: 08-18-2006, 04:00 PM
  4. When to replace coping
    By anotherpyr in forum In-Ground Pool Construction and Repair
    Last Post: 05-11-2006, 11:33 AM
