Thread: Polaris 360 vs 340 - Current/past users please!
    Lenny is offline Lifetime Member Thread Analyst Lenny 0
    Wilmington, Delaware
    Default Re: Polaris 360 vs 340 - Current/past users please!
    I've used the 360 for several weeks between this year and last.
    It does a good job, but not great. My biggest complaint is that it doesn't climb my stairs. I had to fiddle around with the hose connections and hose length quite a bit before I got everything right but it's pretty much trouble free now.
    I opened early this spring (mid April) and I have to say that it's done a pretty good job with a hell of a mess.
    Mesa, AZ
    The 340 has a problem with a worm gear in the drive mechanism that tends to break. Until recently the worm gear was only available as part of the gearbox for about $215 One of our local pool stores recently started stocking the gear for about $17 One of the other good pools stores has a big pile of dead 340s they use for parts.
    Sherra is offline Lifetime Member Weir Watcher Sherra 0
    South Carolina, United States.
    Thank you all for your feedback.
    If you have a dedicated pressure line, have you considered using a Polaris 280 with a booster pump. I think this would give you the best performance.
    I want to avoid a booster pump...I simply do not want to deal with paying an electrician to come out and rewire for the pump and put in a new timer and pay for the extra electricity to run an extra pump. I just want to avoid having to be out and vacuuming my pool for an hour to an hour and a half each time we go out to use it. Yes, I literally spend that much time manually vacuuming the sand from the bottom of my pool.
    Sherra
    Kershaw County South Carolina
    (previous AG pool owner)
    My 360 is very powerful and, in fact, I have to think about adjusting my valve positions to decrease it somewhat.
    Yesterday it swallowed a fairly large frog.
    Mahwah, NJ, USA.
    Another possible solution is a better Vac head. Check out "Cleaning Tools" on the main order page. I have both a Polaris 280 (with booster pump) and this vac head and found the vac head to be much faster than the brush head given to me by the builder. Good Luck.
