Thread: Water level has risen too high in closed pool
    Jul 2011
    Default Water level has risen too high in closed pool
    Hey guys,
    Eagerly awaiting for the new pool season to arrive. We've had a lot of heavy rain storms come through recently and the water has risen in the pool to the point of touching the cover and I believe it might be up to the coping. What is my best course of action? Do I remove part of the cover and drain out some of the water? If so, how much?
    Something else i need to do?
    Thanks as always
    25,000 gallon Concrete/Plaster Pool with a D.E. Filter. K-2006 Test kit. Pool Forum Rocks!
    Jul 2011
    Default Re: Water level has risen too high in closed pool
    I drained the water so its about 4-5 inches above the returns. Is that an appropriate amount?
    It's probably OK.
    But to have any confidence in the answers you receive, you'll need to ID your locale AND how you winterized, if you did so. If your skimmers are 'wet' AND below the water level AND you are in freezing area, lowering the water below the skimmer body can result in freezing. But of course, that depends on the relative levels of the skimmer body and your pool returns.
  1. water pouring out of equipment when pool was closed for winter
    By wishIcould in forum Pool Equipment & Operations
    Last Post: 01-09-2013, 05:08 PM
  2. High PH level while shocking pool question??
    By Pipecrew in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 09-04-2011, 03:07 PM
  3. Pool store said my phosphate level is too high
    By debdevero in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-29-2008, 12:43 PM
  4. Water has risen to the skimmer
    By nyjobz in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 02-15-2008, 08:28 AM
