Thread: Solar cover for a kidney shaped pool
    Indiana.
    Default
    A reel can be used on a kidney shaped pool. It has to be placed in the middle of the pool, so putting the cover back on isn't quite as easy as it would be for a rectangular pool, but easier that no reel at all.
    Question Solar cover for a kidney shaped pool
    Quote Originally Posted by JohnT
    Can someone suggest something else?
    Is the middle of the pool really the only way to do it?
    Default
    I have a figure 8 shaped pool and the pool store said the reel should be placed over the widest part and the cover folded over it before you start cranking. I assume the same would work for a kidney shape which is simialar.
