Closed Thread
Results 1 to 10 of 11
Thread: Pure and Clear SWG
    Default Re: Pure and Clear SWG
    Thanks for the reply Pat. Where did you find the manual on-line?
    The white clould disipates and does not cloud up the pool. I'll check the chlorine readings tonight.
    ~25,000 Vinyl pool
    Pure and Clear SWG; Hayward Pro Series filter
    Purex Triton Minimax+ Heater; Magnatek Centurion 1 hp pump; PCS Infinity 2000 Cover
    Saint Cloud, FL
    Typed in Pure and Clear in Google without SWG, and came up with the URL below. It's the second PDF. The white cloud then is the hydrogen as I thought.
    http://www.gpspool.com/customer/gepo...clear_tech.asp
    Pat
    Thanks Pat. The chlorine levels at the cell are much higher (~ 4ppm). So, it looks like the cell is working. I'll keep reviewing and looking for a replacement, but for now it looks like it might make it one more summer.
    Which SWG do you have, or which do you like?
    ~25,000 Vinyl pool
    Sacramento, CA
    Pure & Clear is obsolete, company was bought out by Polaris a few years ago, but Polaris does NOT support the Pure & Clear model .
    You can get replacement (remanufactured) cells here http://www.saltcells.com/replacement...c-21_108.html;
    I've also seen at least one other place that was selling "original" equuipment (suspicious of this)
    I have the Pure & Clear also, but my cell is totally dead now. Iwas thinking of ordering the replacement cell (for $250) but my unit has a few problems besides the cell: the pump sensor circuit does not work - the unit thinks the pump is running all the time. I traced out the circuit, and I can't see that it ever could work.
    Does the "period" LED between the 2 numbers blink about 1 per second with the pump on and pump off like mine does? The blinking "dot" indicates that the unit thinks the pump is running .
    I also noticed that 2 large electrolytic capacitors in the power supply are "bulging" which is a bad sign
    All in all, I'm thinking of ordering an entirely new SWG system for around $700
    good luck
    Mike K
    Saltcells.com does not have reman replacements. I did find one vendor that claims to have 6 original cells left at a price of $262. I'm like you though, I think that money may be better spent on a replacement system.
    Mine does know when the pump is on or off.
    Which system are you thinking of buying?
    ~25,000 Vinyl pool
    Sacramento, CA
    I'm looking closely at the "AquaRite" made by Goldline,company just purchased by Hayward. Since Hayward is a big name in pool equipment, and the AquaRite has a 5 year warranty, I'd feel a lot better than buying from small unknown company, like Clear-Tech was!!!
    Priced less than $700 on the New, doesn't include installation , but I can probably handle the electrical, and pay $75 - $ 100 to plumb it.
    Mike K
    Quote Originally Posted by mrmrk49
    Mike K
    Have you called Polaris about their "upgrade" to an autoclear? I like the aquarite also. I'm curious though, if you can handle the electrical, don't you think you could handle the plumbing? From what I've seen/heard, it looks very simple.
    Greg
    ~25,000 Vinyl pool
Closed Thread
