Pure & Clear is obsolete, company was bought out by Polaris a few years ago, but Polaris does NOT support the Pure & Clear model.
You can get replacement (remanufactured) cells here http://www.saltcells.com/replacement...c-21_108.html;
I've also seen at least one other place that was selling "original" equuipment (suspicious of this)
I have the Pure & Clear also, but my cell is totally dead now. Iwas thinking of ordering the replacement cell (for $250) but my unit has a few problems besides the cell: the pump sensor circuit does not work - the unit thinks the pump is running all the time. I traced out the circuit, and I can't see that it ever could work.
Does the "period" LED between the 2 numbers blink about 1 per second with the pump on and pump off like mine does? The blinking "dot" indicates that the unit thinks the pump is running .
I also noticed that 2 large electrolytic capacitors in the power supply are "bulging" which is a bad sign![]()
All in all, I'm thinking of ordering an entirely new SWG system for around $700
good luck
Mike K
