Thread: No flow light on
    Jan 2012
    Default No flow light on
    My no flow light is on my salt system. What can I do to fix it?
    Default Re: No flow light on
    There are a number of people here who are knowledgeable about specific models of SWCGs. So do this:
    1. Find your exact model # and manufacturer name. Write that down.
    2. Check that there IS adequate flow past the cell -- valves open, pump basket clear, filter clean, etc.
    3. If there IS adequate flow, and the light remains off, power cycle the SWCG. Leave it off for several minutes, then turn it back on.
    4. If you've verified that there is FLOW, and if power cycling doesn't fix anything, reply, but INCLUDE the model and make info.
  1. Hayward Swimpure + No Flow Light Flashing vs. Solid
    By raddrider in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-26-2013, 08:58 PM
  2. Hayward Swim Pure + No Flow Light Flashing vs. Solid
    By raddrider in forum --cleanup--
    Last Post: 05-26-2013, 03:04 PM
  3. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
  4. Design flow rate vs maximum flow rate...
    By cruzmisl in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 07:50 AM
  5. Aquarite "No Flow" light.
    By Number6 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-18-2006, 10:45 PM
