Results 1 to 10 of 18
Thread: Gallons of muriatic, days of aeration...
    Default Re: Gallons of muriatic, days of aeration...
    Quote Originally Posted by CarlD
    I have to agree with Michael--try to hit 7.0. But you DID say you have a concrete pool didn't you? You are a lot safer if you go too low with pH than a vinyl pool owner.
    that's why I said to shoot for 6.8 by adding acid in small amounts and testing until you got there.
    Thanks all, here's the latest:
    I put in a gallon of muriatic, let it run for 2 hours, got the pH to the light end of 7.2 (using Taylor kit). Just added in 1/3 gallon of muriatic to get it to drop down to the 6.8 range. BUT, before I added additional acid, I measured the alk and it said it was down to 140. Yay, Progress!! The thing is, I had a 130 on Friday morning, and then by Friday evening, it was back to 190, so I don't trust these low numbers that I get. Think I might have some errors in my methodology...
    New muriatic has been circulating for a couple of hours, and then I'm going to fire up the fountains over night to see (hopefully) a lower alk # in the AM.
    Michael, I apologize for not giving you proper credit for your calculator in my earlier post. It is a godsend. Thank you.
    I appreciate the warning on not going too low on pH--my kit only goes down to 6.8. I'm going to *assume* that I'm there right now and just aerate like crazy tonight so I don't damage anything.
    Thanks Everyone for all the helpful info! I'll post again tomorrow w/ the new numbers.
    Quote Originally Posted by Sigrid
    Wehn you lower the pH you shift the buffer system to more carbonic acid (carbon dioxide gas dissoved in water) so when you test TA it will give a lower reading. As the pH rises back up the buffer shifts to more carbonates/bicarbonates so when you test the TA it will test higher since the test will tell you how much alkaline carbonate ions are in the water. This is normal. The idea is to 'gas off' as much of the carbon dioxide gas that is formed by the lowered pH so that when the pH rises less of the alkaline carbonates are formed and your TA is lower. The process CAN take a while.
    This is why I cautioned to make SMALL additions of acid and test pH once the pH starts moving. It is very easy to overshoot! With a plaster pool it is ok to go to as low as 6.6 according to Ben's sticky on the subject as long as you have an accurate way to test for pH that low (such as a pH meter or the correct indicator solution and comparator for that pH range)
    Hope this is helpful!
    Good morning!
    After dropping pH to something less than 7.2 last night and aerating overnight, I tested this morning at 7.5 pH and Alk at 130! That looks like progress and I'm delighted.
    Waterbear, if I understand correctly, I can actually trust this alk number because the pH already went up, right?
    I'm hoping that's the case. I just put in another 1.5 gallons of muriatic and will be aerating all day. Targeting alk in the 80-90 range (high alk fill water, heater).
    Everyone, thank you so much for all the help and sharing your insights with me!
    --Sigrid
    Katy, TX
    Quote Originally Posted by waterbear
    Regardless of how small of an amount you add, when you are at the bottom of the scale, you can be past 6.8 and not know it, hence my caution.
    Michael
