Thread: Bioguard Generating Sanitizer light not coming on
Threaded View
  1. #6
    Default Re: Bioguard Generating Sanitizer light not coming on
    Yes, Jerry, we were able to determine that the green light wasn't coming on, from your first post. It's not clear why you'd ask the same question twice, and not respond to any of the efforts to help you.
    Where are the test results Waterbear asked for? Did you read the Goldline manual Waterbear linked for you? What is your water temperature?
    Like I said, your response doesn't make sense . . . unless a spammer or a troll has hijacked your email and identity.
    So I checked your IP, and since it was a dynamic IP , I checked the IPs near you. Other then some posts on a Harry Potter wiki, your IP doesn't have a visible bad history. But dynamic IPs can be changed easily and there are a LOT Of spammers in your immediate IP neighborhood, far more than is typical. Clearly, someone in your neighborhood is engaging in criminal Internet activity.
    So, I'm banning you. Email me at poolforum AT gmail DOT com, if there's a legitimate reason why you asked the same question twice, and didn't respond to any of the first posts trying to help you.
