Results 1 to 5 of 5
Thread: Electronic help
    Feb 2012
    texas , usa
    Default Electronic help
    Hello all,
    I have a money pit (Pool) fresh water . My Pentair Easy Flow box is having some major issues.
    1) Started filling the pool all day instead of 5 min a day.
    2) The pump cycle turns off and on.
    3) The digital screen is going crazy and just not working right.
    I have done alittle research on it and found I am in need of a motherboard replacement. I am thinkin of just replacing the entire unit. Any other thoughts?
    Gregg
    Default Re: Electronic help
    You mean "Easy Touch", right? Like this:
    http://www.pentairpool.com/pool-pro/...systems-49.htm
    I'll move your thread out where others can see it; I have no personal experience with those systems.
    Feb 2012
    texas , usa
    My mistake . Yes "Easy Touch".
    Jun 2010
    Portland, OR
    try turning the unit off at the panel for a few minutes might just need to be resit
    Good point, Brad. Power cycling electronics is often appropriate as a first attempt at a solution.
    When I'm having to help friends and family with computers, one of the first things to say is always, Have you power cycled your PC?. I know my DroidX phone gets seriously confused every couple of weeks, and has to be cycled.
