Thread: Electronic help
    Feb 2012
    texas , usa
    Default Electronic help
    Hello all,
    I have a money pit (Pool) fresh water . My Pentair Easy Flow box is having some major issues.
    1) Started filling the pool all day instead of 5 min a day.
    2) The pump cycle turns off and on.
    3) The digital screen is going crazy and just not working right.
    I have done alittle research on it and found I am in need of a motherboard replacement. I am thinkin of just replacing the entire unit. Any other thoughts?
    Gregg
    Default Re: Electronic help
    You mean "Easy Touch", right? Like this:
    http://www.pentairpool.com/pool-pro/...systems-49.htm
    I'll move your thread out where others can see it; I have no personal experience with those systems.
    Feb 2012
    texas , usa
    My mistake . Yes "Easy Touch".
    Jun 2010
    Portland, OR
    try turning the unit off at the panel for a few minutes might just need to be resit
    Good point, Brad. Power cycling electronics is often appropriate as a first attempt at a solution.
    When I'm having to help friends and family with computers, one of the first things to say is always, Have you power cycled your PC?. I know my DroidX phone gets seriously confused every couple of weeks, and has to be cycled.
  1. electronic tester?
    By 131441 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-06-2012, 06:28 PM
