Thread: Recommended cleaning robots?
    May 2010
    Default Re: Recommended cleaning robots?
    I can't recommend a robot, but I will suggest that you get an in-line leaf basket. My pool cleaner is vacuum operated, not electrical, and it will not climb anything, but the in-line leaf basket keeps tons of leaves out of the filter.
    May 2011
    Batesville, MS
    If you go the Polaris route, stay with the 280, the orifice is bigger and it is a little more economical in the beginning...
    18x36 IG Vinyl...Jacuzzi Pumpworks (the bane of my existance), VERY small pool biz - Full time Science and Math teacher!
  1. clarifer, recommended or not?
    By pbotz2000 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-19-2012, 09:56 AM
  2. Why is dichlor not recommended?
    By Farmingtonpool in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-23-2012, 03:05 PM
  3. Are some robots better than others with gunite?
    By Enigma869 in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-17-2007, 11:30 AM
  4. Recommended resurfacers in AZ?
    By JasonA in forum In-Ground Pool Construction and Repair
    Last Post: 11-17-2006, 02:26 PM
  5. Robots vs. Manual
    By cheshamjim in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-14-2006, 01:08 PM
