Results 1 to 10 of 11
Thread: Getting things ready...
    jilted is offline Registered+ Thread Analyst jilted 0
    Jun 2011
    Louisiana
    Default Re: Getting things ready...
    It was running close to 12 hours. The CPSC36 has a built in test that seems pretty accurate. I tested it last year against a strip and the results were approximately the same. After a couple hours the unit reported 2700 ppm and then about 8 hours later it was still reporting 2700 ppm. I didn't get home in time to add another bag this evening. I'm going to work with it all weekend. I'll get the salt up first. So far it looks to be 100'ish ppm per bag but I'll take it slow so I REALLY get a good estimate.
    Yes I am interested in how to speed up lifting the stains!
    Thanks.
    26,500g inground vinyl liner (new liner installed June 2013)
    Hayward 1.5 HP Super Pump - Hayward sand filter (sand changed in spring 2009)
    Compu Pool CPSC36 SWCG - Polaris 380 cleaner
    Jun 2011
    Louisiana
    While adding salt and brushing it around to help dissolve, the brush caught the corner in the shallow end and caused a tear in the bottom! I jumped in today and put a patch on it. This was not fun as the water was 60 F. After patching, I had to open the pipe that sucks water out from behind the liner so I lost an inch or so of water.
    In other news, even after adding fresh water, the salt level is reading 3500 ppm. Now on to CYA I guess... after I make sure the patch worked.
    Brrrrrrrr!!! I'm glad to see you didn't go into cardiac arrest! On a positive note, I saw on Dr. Oz the other day that taking a cold shower in the mornings increases your metabolism. You should be good to go with that now!
    Glad to see you back around the forum this year!
    Jun 2011
    Louisiana
    Added some CYA last Sunday and did another run of tests today:
    Salt: 3400 ppm
    CYA: 60 ppm
    Alkalinity: 80 ppm
    pH: 7.6
    Free Chlorine: 5.5 ppm
    Combined Chlorine: 0 ppm
    Temp: 77 F
    Pool has been running non stop this week since I added 3 lbs of CYA.
    SWCG was off for a few days after adding CYA and then I kicked it back on like Wednesday at 50% output so I'm sure thats why my FC is so high right now, not to mention the CYA is increased.
    Also, it rained a TON here in Louisiana this week! So my pool was topped off for a few days until the overflow drain trickled it back down.
    Waste mentioned something about speeding up lifting the organic stains. What can I do to work on that?
    Thanks!
    -stephen
    Jun 2011
    Louisiana
    OK so my water seems to be in good shape now. CYA didn't seem to increase much after the second 3lb bottle... maybe 65-70ppm?
    So what (if anything) can I do about these stains? Not extremely worried about it since liner is getting replaced but if it's not too hard to clean up I would like to.
    Thanks,
    -stephen
    Hi!
    The key to lifting organic stains is chlorine, the higher the concentration in the stained area - the more quickly it will lift. Unfortunately, high chlorine levels are bad for liners. Mbar is the resident stain expert, I'd suggest searching the site for stain removal tips. (IF you want to spot treat the area, I'd use cal- hypo in a kneehigh and keep a close eye on it!)
    I don't mean to be terse, but my computer is giving me LOTS of trouble of late and I'm trying to keep my posts short and sweet.
