Re: Getting things ready...
While adding salt and brushing it around to help dissolve, the brush caught the corner in the shallow end and caused a tear in the bottom! I jumped in today and put a patch on it. This was not fun as the water was 60 F. After patching, I had to open the pipe that sucks water out from behind the liner so I lost an inch or so of water.
In other news, even after adding fresh water, the salt level is reading 3500 ppm. Now on to CYA I guess... after I make sure the patch worked.
26,500g inground vinyl liner (new liner installed June 2013)
Hayward 1.5 HP Super Pump - Hayward sand filter (sand changed in spring 2009)
Compu Pool CPSC36 SWCG - Polaris 380 cleaner
