Thread: Pump Question
    Jun 2010
    Mississippi
    Default Pump Question
    I need to replace my pool pump this year. I have a 1.5 Pentair Dynamo on a SD 60 filter. Do I need to go back with the 1.5 or get a bigger pump?
    Pool is 33' app 30,000 gal above ground.
    Thanks for looking.
    I
    33'x33' round 28K gal AG vinyl pool; skimmer BBB; Sandollar 60 200lb sand sand filter; Pentair 1.5 pump; hrs; Taylor; well; summer: none; winter: none; ; PF:4.3
    mas985's Avatar
    Pleasanton, CA
    Default Re: Pump Question
    You shouldn't reallly need a bigger pump and you might even want to look at something smaller to save in energy costs.
    Mark
  1. Question about heat pump pool heater and fireman's switch on pump timer
    By HuntnHog in forum In-Ground Pool Construction and Repair
    Last Post: 04-20-2011, 08:37 PM
  2. pump question
    By jrtvols in forum Pool Equipment & Operations
    Last Post: 02-07-2007, 11:33 PM
  3. Another pump question...
    By LITTLEJJ in forum Pool Equipment & Operations
    Last Post: 11-08-2006, 04:06 PM
  4. Pump Sizing Question
    By liz+3 in forum Pool Equipment & Operations
    Last Post: 06-27-2006, 10:45 PM
  5. Pump timer question
    By The Raddish in forum Pool Equipment & Operations
    Last Post: 06-20-2006, 03:36 PM
