Thread: Deck fountain PVC pipe green algae
    Feb 2012
    Chesapeake, VA
    Default Deck fountain PVC pipe green algae
    So we recently purchased this house with a pool and there is a PVC pipe directed straight up uncovered towards the sky. Took a look today and it was filled with standing water and green algae. I took some extra PVC pipe and made an attachment so it wouldn't blow into the pool and with pump running I opened the valve which was isolating it. I blew it out for 10 seconds then shut valve, soaked up some water then poured in a dose of CL. And covered pipe. Should I shock the pool and refill that piping with the new water after shocking or should the CL I added do the trick? It's the longest piping length as its furthest from pump.
    8500Gal SWG (T-15), outdoor IGP, Vinyl, Pentair 3/4HP 85GPM, cartridge filter, BBTCell
    US Navy 2005-Present USS John F. Kennedy, USS Carl Vinson, currently on Shore Duty Norfolk, VA
    Default Re: Deck fountain PVC pipe green algae
    Quote Originally Posted by Goolsbymd View Post
    Any idea why? Can you post a pic? Most deck jets are not just plain PVC and are buired in the deck in a box. Sounds like itwas a place where there was some type of water feature that was removed or possibly a hookup for a slide.
    Feb 2012
    Chesapeake, VA
    It's for a water feature, it is in a hole with a safety plastic cover over it. However the plastic cover has a hole the exact location where the PVC pipe is lol.
  1. Replies: 8
    Last Post: 08-04-2012, 11:43 PM
  2. Kool-Deck with Algae Problem..will stain/sealer help
    By mneal in forum In-Ground Pool Construction and Repair
    Last Post: 09-26-2007, 07:43 AM
  3. Green algae? Mustard algae?
  4. Can I glue a threaded pipe into a smooth pipe??
    By adl6009 in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2006, 12:19 AM
  5. Green Algae
    By lynn2_cal in forum Dealing with Algae & Slime
    Last Post: 06-18-2006, 08:53 PM
