Hi, Mike/Scott,
When I built my pool, the consensus was to pump enough water to turn over your pool 2-3 times a day. (on high speed) (30,000 gal pool needs a pump to turn approx 75,000 gal in a 24 hour period......52 gal per minute.)
Then, choose a filter that is rated (in gpm) of at least 110% and maybe 130% of that 52 gpm....say, around 60-80gpm.
The trick will be in calculating total head of your pool so you can look up the curve of a particular pump and see if it satisfies your requirements.
I seem to remember an average pool has a total head of about 50 but I think there are others on this forum who have better info on that.
My pump and total head computed out to about 90gpm on the curve (1.5 full-rated) so I got a filter rated @ 140 gpm.
To summarize, compute how much water you need to turn, get an average idea of your total head, find a pump curve that matches that, get a bigger filter.......you're good to go.
Dave S.
