The most accurate way to determine head is to measure it.
What is your filter PSI? Multiply it by 2.31 to get return head.
Suction head you can get with a vacuum gage (Sears has them for $20). Multiply in mg by 1.13 to get suction head, then add together. Once you have total head you must scale it by GPM of the new pump. Unfortunately, it is an iterative process because GPM and head are dependent upon each other. I use a spreadsheet with hydraulics equations to solve for each.
For comparison, I have a 21,000 Gallon pool with 2.5" & 2" plumbing, filter, heater, spa and 1HP Northstar pump. From measurements that I took, my head is about 56' @ 92 GPM.
Also, if I had a bit more information, I could estimate head for you and what it would be with a different pump.
Current Filter PSI
Equipment list
# Suction lines, ~ length & dia
# Return lines, ~ length & dia
The rest I can guess.
Well, current filter psi is a bit of a problem. When I took everything out of service for the winter, "normal" filter psi after backwashing was about 4 psi. The problem is that I get crap for flow. The filter is a 48 sq ft stainless steel nautilus with pin-hole leaks and a leaky seal. The pump is a old bronze 1.5 hp aqua-flow, which I understand eats impellers. The system is shot, so any pressure reading I get is probably bogus. I can never get the filter psi over about 8.
When I bought the house, the pressure guage didn't work (I plumbed in an automotive pressure gauge just to get enough sensitivity to see if the system worked). The pump had no strainer basket and the pool skimmer had no basket. I took apart the filter and it was completely full of very brown DE. I replaced one grid, patched two more grids and several grids had internal stiffeners cracked and broken and I just left them. I only had two months of usable season left and knew I would replace things in the off season.
The suction line I would estimate at 36 + 18 + 10 feet or 74 feet. Its a 18 x 36 pool and the equipment is maybe 10 feet off the corner furthest from the skimmer. The return I would estimate at 10 feet as its a straight shot to the pool corner. All piping is 1.5" except between the pump and the filter, which is 2". Equipment would be a 48 sq ft DE filter a 1.0 full rated or 1.5 up rated pump and a in-line clorinator, unless something else looks like better match. The pump is intended to be two speed.
If you can provide some rational numbers, I would appreciate it. I plan to go down to leslies pools and order some stuff tomorrow morning. They are having a 20% off sale, so they are very competitive with an internet purchase. Right now we are looking at the hayward products, the 1.5 hp super II pump and the 48 sq ft FNS filter. I'm also considering pentair products, but leslie has less of a selection of that brand for sale.
If you only have 1 skimmer and 1 return line, your head will be quite high with a full rate 1 HP pump. I estimate over 70 ft of head which is mainly due to the 1.5" 75 ft of suction pipe.
The maximum recommended GPM for 1.5" pipe is about 42 GPM. If you go with a 3/4 HP, the head will drop to 60' @ 57 GPM. At 1/2 HP, the head will drop to 47' @ 50 GPM. These are only approximate since it depends on the pump type.
Here is a web site to help with pump sizing:
http://www.poolplaza.com/pool-pump-sizing-2.shtml
Basically your telling me that its about impossible to optimize my pool. If I go with a 3/4 hp pump, then I'm slightly overdriving my plumbing. I might be able to live with that, but then, on low speed, I'm basically moving not enough water to turn over my pool. Low speed is 3/32nd hp. Not much flow and thats a lot of water to move. I think I can get maybe 20 GPM or so at low speed, but since TDH goes down with the lower velocity, I have not idea what it is.
To turn over a 25000 gallon pool in 8 hours requires 52 GPM. Since I can only get 44 GPM out of 1 1/2 inch pipe, this is impossible.
Aparrently the 44 GPM comes from the building code requirement to not exceed 8 ft/sec in the pipe. A pipe can technically support the flow, but pipe damage can occur. Thus, I can exceed 44 GPM and the pump shouldn't cavitate or do evil things.
A better match is the 1/2 hp pump, but then I'd get essentially nothing out of low speed, if I can find a two speed pump.
The most correct answer is to add a second suction and return or convert to 2" pipe, both which are essentially impossible on an existing pool. I actually have a second return. That is intended for a pool cleaner with a booster pump. Since the pressure side head isn't a large contributor compared to the suction side, I don't think it would help much.
Hi, Mike,
Mas985 has given you some great info but you seemed to shuffle it aside maybe a little too quickly. Two thoughts come to my mind....Could you get your .75 2-speed pump (for the rebate) and run it on high all the time? Seems simple enough.
When you get your new pump and filter, could you replumb your booster pump line to become a suction line...or perhaps perform both functions if you use the booster pump.
I will also promise you can push more than 44gpm thru a 1.5"pipe without harm....been there, done that.
Impossible to optimize your pool? Optomize means doing the best you can....not perfection, but the best you can do with what you've got. I think you can improve your system markedly with a little more planning.
Dave S.
No, I'm not trying to push his information aside. I very much appreciate it. I agree that getting a downsized pump and running it on high most of the time is a rational plan.
The problem I see is that going too small won't allow me to get a decent turn-over rate.
I've been doing a little more research and it does appear that I can push a bit more flow that 42 GPH even though its not the best idea. Something on the order of 55 GPH or so.
The thought of using the booter line as a second suction line is very intriguing. That would be terrific if I can do it.
The port on the side of the pool is maybe 18 inches below the surface. Would this really work? BTW: The only reason I call this the booster/cleaner line is that what the previous owner called it and there is an unused booster pump in the pool house. He said he threw his cleaner away because it didn't work.
Can I have 2 1.5 inch suction lines and a single 1.5 inch return?
ALso, thanks everyone for helping me through this.
Hi, Mike,
I would envision the suction side plumbing something like this...two 1.5 lines, contolled each by a ball valve, coming from the skimmers and the booster line, teeing into a 2"line at least 12" long that goes into your pump. Even if you have to come back down to a 1.5 entrance into your pump, that 2' tee will reduce some turbulence and, therefore, TDH.
The downside is that you would have an open suction line on the side of your pool that could grab somebody and could actually be a little dangerous if, for some reason, you shut off the skimmer suction line. You can buy a little plastic guard to screw into that booster line which will greatly help, but not eliminate, that issue.
If you really wanted to get complex, you could tee off that booster line with some more plumbing so it could be controlled as a suction side or pressure side line. I doubt that's a great idea, but it could be done if you needed to.
Mike, if you can get 50gpm through there, that's 24,000 in a 8 hour period which I think gets you right about where you want to be. Others smarter than me may nix this whole idea but it seems to me it would work nicely.
Dave S.
I'd like some help from the experts too as I'm also looking to go with a two-speed pump.
16x32 foot in-ground w/ vinyl liner. 19,200 gallons before we put steps in the corner last summer.
All 2" pipe.
24" SplashPak Sand filter
2 suctions (only one running at a time) - 1 is 17' (skimmer) run and the other is 27' (vacuum). I believe each has 3 elbows before the 2 near the pump.
1 return is 24' with 4 elbows.
Thanks in advance!! Ken
Hi, Ken,
You'll get much more attention if you start a new thread. Much easier for folks to find and subscribe to.
Dave S.
Dave S.
